2024-04-19
04:08 AM
2024-12-30
05:36 PM
Molinda Prey
Hi, I would like to know if there’s any chance to hide the other level. I would greatly appreciate it if you could help me.
in the elevation. Thank you.
Solved! Go to Solution.
2024-04-19 08:11 AM
2024-04-19 04:44 AM - edited 2024-04-19 04:45 AM
That would depend on the storey level marker you are using.
In the elevation settings you can choose the storey marker.
For the default 'built-in' marker ...
2024-04-19 04:48 AM
Thank you, I will try that one.😊
2024-04-19 05:52 AM
You are not just wanting to hide the entire AHD grid are you?
2024-04-19 07:56 AM
Yes, entire AHD.
2024-04-19 07:59 AM
Where I can find the photo you attached?
2024-04-19 08:07 AM
That is in the Storey Settings.
2024-04-19 08:11 AM
is that in elevation view then elevation settings?
2024-04-19 08:14 AM
Just the Storey Settings - right click on 'Storeys' in the Project Map.
2024-04-19 08:21 AM
The check marks on the right side determine whether that storey grid will show up on your elevaitons and sections. There is no per-view setting for it so what ever you choose will be uniform across all of your elevations and sections which you have chosen to show the storey grid on.
Ling.
