How can I edit the text in a Master Layout?
Denis Aviel
How can I edit the text in a Master Layout to go accordingly to the page if I edit it?
1 REPLY 1
If you adjust the size of a master layout, you have to manually adjust anything you have placed on it.
The idea is that you do not adjust the master page size, you simply create a master for each page size you will require.
So you will have many masters for different page sizes and orientations.
Each master (page size) has the text and border lines set up to suit that particular page size and orientation.
Then in your layout you just choose the master that suits the page size and orientation you want to use.
Setup info provided by author
