LeeJaeYoung
How can I remove windows, etc. from the 3D view, leaving only the structure?
AC27 on window 11
1 Solution
Lingwisyer
Guru
Hm. Did not realise it left a frame reference on... thought the Detail Level in the object was the same as Detail Level under MVOs... I guess you could filter (ctrl + alt + a) your windows out? This is saved with your View.
Go to post
11 Replies 11
Lingwisyer
Guru
Use the Partial Structure Display option? Or create a MVO for it.
LeeJaeYoung
Set Partial Structure Display to core and
Even if I set mvo to the maximum, the window does not disappear.
AC27 on window 11
Lingwisyer
Guru
That appears to be the Opening Line, which can be toggled off under the MVO Miscellaneous Settings.
LeeJaeYoung
I don't think that's the answer.
thank you
AC27 on window 11
Lingwisyer
Guru
These are default AC windows right?
LeeJaeYoung
Yes, it is a different window from window 25.
AC27 on window 11
In the MVO settings, 'construction elements' only affects the plan view.
'Detail level' affect the 3D but even with 'Schematic' you will see lines representing the shape/configuration of the window.
In the actual window settings there is an option to turn the 3D off entirely.
But because it is an object setting, you can't control it with view settings, i.e. have the window show for one view but be off in another view.
Lingwisyer
Guru
MetalFingerz
I would filter out the window from the View / Filer and cut elements in 3D menu : https://helpcenter.graphisoft.com/user-guide/77412/
