How can you show the cover fill of roof in the elevation?
Should I use 'fill' for the roof surface?
'cover fill' option doesn't look like working for either floor plan or elevation.
Each time when I change the roof, I have to change the 'Fill' of roof.
If anyone know how to show the roof cover fill,
I'll really appreciate.
3 Replies 3
The cover fill will only be seen in the floor plan.
If you want to see a hatch pattern in the elevation then use a materail on the top surface of the roof that has a fill (hatch pattern) associated to it.
Then make sure that the vectorial hatching option is turned on the the section/elevation settings.
cheers!!!
I will try
BTW: You can set the cover fill to match the 3D material for full coordination.
