Mats_Knutsson
Mentor
How do you create room layouts in large projects?
Reaching out because I'm stuck.
I want to create "Room layouts". A room layout is per room and consists of IE-elevations, a plan view of the room. The layout name has to be the same as the room number. How do you create these layouts in larger projects? I have 350 of them to create...right now I'm publishing the IE groups as .pmk and mount them one by one on every layout (since I can't place more than one .pmk at a time on a layout). Keeping the room layout in the main file is not possible because it's bogging down the file.
See nicely handmade draft...
Best regards,
Mats
AC 25 SWE Full
7 Replies 7
Hello,
Would your object be to automate this process (cuts, plans and layout) ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
HI,
Have you tried hotlink modules?
Cheers
Mats_Knutsson
Mentor
Christophe wrote:
Hello,
Yes as much as possible.
AC 25 SWE Full
Mats_Knutsson
Mentor
tranthainguyen wrote:
HI,
Cheers
Tha majority of the rooms in the master file comes from hotlinks. I'm after the layout creation.
AC 25 SWE Full
If you have to (or want to) publish as PMK files as you are now doing, then I don't think you have any choice except to add them all one by one.
However you can just drag the IE view group to the layout page and all elevations will be added at once.
I think you can adjust the layout grid spacing to get them to align how you want them.
This can also be done in a separate layout book (separate file).
With the 2 files open in separate Archicads, open the Organiser in the layout file.
Browse for the project file and simply drag the views across onto the layout page.
You may have to select them and then 'Update'.
Or you can choose to 'Place External Drawing' and then browse for the model file and the views you want (this can even be done with the model file closed).
The plan you will have to add in the same way - unfortunately it is not part of the elevation group.
Erwin Edel
Copying the layout and re-linking the views (and moving them if needed) is the only thing that will slightly speed this up.
I assume it's 350 unique rooms, or I would've set up some sort of sub ID system with room type A, B etc and considerably shorten the amount of drawings needed.
I've never had to do something like this with rooms, but we do have it with building types a lot and for this reason we make sure to have seperate building type PLN with everything set up the same in terms of project origin, this makes re-linking layouts a lot quicker, since there is no need to move the placed drawing after re-linking.
You could maybe make publish PLN files where you place the room MOD files and setup the interior elevation. If you put, for example, the bottom left corner on origin in all these files and then publish PMK, if you re-link each layout, the drawings shouldn't jump around. It's probably less work to move the MOD files to origin in a seperate PLN. If you keep them as linked drawings, instead of PMK, if the MOD updates, the layout should automatically update as well.
Just throwing some ideas out.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
We've hade problems with copying before...it was several years ago but the drawing update got wrong and I really haven't taken the method to my heart.
I've prepared a master with a grid (which works sometimes and sometimes not).
AC 25 SWE Full
