How to See Through Objects in a Section View (Point Cloud issue)
byMarkus
Dear Graphisoft Support and Community,
I am writing to seek assistance with a specific issue I have encountered while working with ArchiCAD, and I would appreciate any guidance or solutions that the community or support team may be able to provide.
Issue: I am currently experiencing difficulties in visualizing point clouds through objects in ArchiCAD's Section view. Despite my efforts, I have been unable to find a suitable solution to make objects transparent or visible in wireframe mode, allowing the point cloud to be visible through them. To clarify, I am able to do this in both 3D and a Floorplan view, but not in a Section view.
Attached a picture to further showcase what I am looking to solve (Example I made in Revit)
Sincerely,
3 REPLIES 3
Does setting the layer the object is in to 'wire frame' affect the section view?
It certainly works in 3D.
I don't have Archicad open at the moment to check.
The wireframe option actually just removes the whole object from the section view. Similar to the eye button next to it, that hides the object. I'm pretty sure this solution only works in 3D view.
Anything else that might work?
Sincerely,
c_cignino
You can try with Overwrites setting "Background" fill and transparent background
