How to avoid overlapping level markers in elevation?
Gisele
Is there a way to edit the text size of the level markers to avoid the text overlap in elevations?
Also, can I remove the story number (1, 2, 3, 4, ...)?  Please see attached screenshot.
undefined
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
Lingwisyer
Guru
Elevation Settings => Story Handle Marker Custom Settings => Marker => Show Name / Number => Story Name
That's the setting in the default AUS and INT storey marker. Would not be surpised if it is different in the US marker...
Text size can also be modified in the same dialogue.
Ling.
1 REPLY 1
Lingwisyer
Guru
Ling.
