2013-05-29 01:26 PM - last edited on 2023-05-19 03:57 PM by Gordana Radonic
2013-05-29 05:47 PM
2013-06-30 07:35 AM
2013-06-30 03:01 PM
Text size is independent of the building scale and will print the same size on paper whether the drawing is 1:10 or 1:200.There is a setting for the Text Tool (but not other annotation tools) that switches between Paper Size and Model Size, so be sure you have the correct setting. With Imperial units, the change is more apparent, as the font size changes from points to inches. With metric the change is less obvious.
