Espen da Silva
How to flip section
It might be super simple but I couldn't find an answer for this anywhere. I have a section that is pointing to the left, I would like to flip it so that it points to the right.
From this:
to this:
2 Replies 2
Noemi Balogh
Once the section marker is selected, just simply mirror it.
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F030_Inter...
Noémi Balogh
Senior Community Expert, Admin
Or if your section has a depth limitation, you can select that and then stretch it to the other side with the pet palette option to reposition the section line segments.
