How to get a hotlink module to fade into the background, so every element has a thin lineweight
pcrossington
I'm trying to get a hotlink module to fade into the background. The hotlink is a survey and I want all of the lines within it to be on a particular pen, kind of like a trace reference, where you can fade it i and out...
Thank in advance for your help!
Operating system used: Mac Intel-based sequoia 15.6.1 (24G90)
MitchD
you can use a graphic override to make all hotlniks (or a particular one) have the pen, line, etc. properties you wish.
ArchiCAD 28 /// Win 11 Pro - Ultra 7 155H - 32GB RAM - RTX 4060 8GB /// Win 11 Pro - i7 12700 - 64GB RAM - RTX 3070 Ti 8GB
MitchD
beautiful - thank you!
Setup info provided by author
