2023-05-16 07:07 PM - last edited on 2023-05-16 11:22 PM by Gordana Radonic
in Archicad
in AutoCAD
2023-05-17 04:51 AM
The name of the line type is also the same as dash.
In attach xref, linetype can be set separately.
Still can't do it here?
2023-05-17 05:26 AM
You can see it if you zoom in this much.
2023-05-17 05:48 AM
I changed it to a LINETYPE called WithDash.
However, within archicad, the line type called WithDash is not visible.
So are there other options?
