How to handle LINETYPE in Place External Drawing...?
LeeJaeYoung
in Archicad
in AutoCAD
AC27 on window 11
LeeJaeYoung
The name of the line type is also the same as dash.
In attach xref, linetype can be set separately.
Still can't do it here?
AC27 on window 11
You can see it if you zoom in this much.
AC27 on window 11
I changed it to a LINETYPE called WithDash.
However, within archicad, the line type called WithDash is not visible.
So are there other options?
AC27 on window 11
