How to override door or window fill?
Achille Pavlidis
I'm trying to override the fills of doors and windows, and I cannot get it work.
How do I get to set the Plan symbol fill of a door to be transparent with GO?
I've set a rule that the Doors fills are overriden to "empty fill" which works for the leaf, casing etc, but the Plan Symbol Fill doesn't get overridden...
Why?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Achille,
If you apply a Graphic Override Rule that makes Cover Fills transparent, it will work. I just tried it in AC24 and it works for me.
Achille,
Achille Pavlidis
Thanks Laszlo!
