2023-01-23 04:37 PM
I am trying to import this Linetype from CAD to Archicad. What should I do?
1. I want to import in paper size.
2. Is it possible? I just come in like this.
Solved! Go to Solution.
2023-01-25 08:16 AM
I don’t think there is a way to tell the line type to finish and start with a dash unfortunately.
2023-01-23 05:03 PM
You need to convert the text to lines too.
2023-01-23 06:17 PM - edited 2023-01-23 06:24 PM
I don't understand what you are saying.
Or can I ask for a little longer explanation for the translator?
2023-01-23 06:36 PM
What you said is to draw it as a line and treat it as a symbol. ^^
2023-01-24 12:08 AM
Sorry. I’ll try and explain a bit better. Line types don’t recognise text or letters. You need to trace over the letter with lines and arcs so that the letters become 2D linework too.
2023-01-24 05:21 AM
thank you so much ^^
2023-01-24 05:35 PM - edited 2023-01-24 06:05 PM
is this the best?
The finish was not processed like the bottom part.
Can you make the beginning and end part handle well?
Actually what I want is to ask because I need now to end with a line with no arrows at the start and end points.
2023-01-25 08:16 AM
2023-01-25 08:35 AM
No, not when it is a 'symbol' line type.
The 'dashed' line types automatically show a solid portion at the start and ends.
2023-01-25 11:35 AM
thank you ^^
