LeeJaeYoung
I am trying to import this Linetype from CAD to Archicad. What should I do?
1. I want to import in paper size.
2. Is it possible? I just come in like this.
AC27 on window 11
1 Solution
Lee Hankins
I don’t think there is a way to tell the line type to finish and start with a dash unfortunately.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
9 Replies 9
Lee Hankins
You need to convert the text to lines too.
Lee Hankins
macOS Tahoe (26.0)
LeeJaeYoung
I don't understand what you are saying.
Or can I ask for a little longer explanation for the translator?
AC27 on window 11
LeeJaeYoung
What you said is to draw it as a line and treat it as a symbol. ^^
custom lines - YouTube
AC27 on window 11
Lee Hankins
Sorry. I’ll try and explain a bit better. Line types don’t recognise text or letters. You need to trace over the letter with lines and arcs so that the letters become 2D linework too.
Lee Hankins
macOS Tahoe (26.0)
LeeJaeYoung
thank you so much ^^
AC27 on window 11
LeeJaeYoung
is this the best?
The finish was not processed like the bottom part.
Can you make the beginning and end part handle well?
Actually what I want is to ask because I need now to end with a line with no arrows at the start and end points.
AC27 on window 11
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
No, not when it is a 'symbol' line type.
The 'dashed' line types automatically show a solid portion at the start and ends.
LeeJaeYoung
thank you ^^
AC27 on window 11
