tsarina
I can't save slab as a door leaf.
I have an isue with saving a slab as a door leaf
As you can see on the picture there's no option for me to save it as a door leaf. I don't know what to do.
15 Replies 15
tsarina
Thank you for the answer but sadly the work environment was fine, so it must be something else
Have you loaded all of the 28 global library packs individually (do not load the folder they belong to)?
Or ar you loading the 28 monolith library (which is just the 27 library)?
Could you maybe show an image of your Library Manager?
If you have the default libraries loaded and you are using a default Work Environment, then you should have the option to save ad a door leaf.
Maybe open the default template (FILE > NEW) and see if it works there.
tsarina
I only have this library downloaded, but when I opened a new (default) template everything works. So thank you! But I still want to work out what is wrong with this project file.
Easy.
You need to load the default libraries.
vistasp
Mentor
I had absolutely no idea that macros in the loaded library controlled what object types you could save. Thanks, Barry!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
tsarina
Thank you very much ❤️
