I want you to tell me how to draw a partial plan with interlocking dimensions.
LeeJaeYoung
I'm startled right now
I'm hoping you'll tell me I'm wrong.
I am preparing a partial drawing, but the lines and dimensions are not linked.
1. In the detail drawing, if the drawing is modified and then rebuilt, it is changed to a non-interlocking stupid dimension or deleted.
I'm hoping you'll tell me you're wrong.
This function is also available for partial drawings created by AutoCAD importing xref files.
2. In order to interlock, you should not put a dimension line in the center line by covering it with a fill in the plan view and making a hole. Talk about finding the end line.
All drawings are 1/500 scale. The partial floor plan is 1/100.
I have to go to the dimension at the end to put in the dimension.
And this method should not be used.
The floor plan is only in the inner rectangle and has dimensions in the rest.
AC27 on window 11
10 REPLIES 10
understand. thank you ^^
Saying you can is a big help to me.
It encourages positive thinking and gives peace of mind.
I hope you have a good day today.
AC27 on window 11
