Llian
IMPORT PROJECT LAYOUT
How do I import a previous project MASTER LAYOUT to another project?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
You can use the 'merge' function : File>File Special>Merge then select the Layout book option - this will import all the layouts and Masters from the selected project. Then delete what you don't need...
David Maudlin
Lilian:
If you just want the one Master, open the Organizer, click the pop-up in the upper left corner, choose Browse Project... to open another file, then drag and drop the Master into the current project.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
