2016-09-13
09:48 PM
2023-05-17
09:18 AM
Gordana Radonic
2016-09-13 10:55 PM
2016-09-13 10:59 PM
2016-09-13 11:03 PM
rob2218 wrote:Turn on the On-Screen View Option toolbar. (Under Window>Toolbars). You will find them there.
thanks for the reply.
this isn't a multiple view elevation marker. it's only one in there.
also, where do you turn these on??
turning on the "Highlight Marker Range" and the "Highlight Section Depth" display to make these easier to find
2016-09-13 11:08 PM
Richard wrote:rob2218 wrote:Turn on the On-Screen View Option toolbar. (Under Window>Toolbars). You will find them there.
2016-09-13 11:15 PM
rob2218 wrote:You know that dashed gray line that I mentioned? You need to select THAT. If you do, then you will get nodes at each end of that line which you can stretch. If a limited range marker, the gray line will be hiding under the extents. Worst case, you can temporarily switch to an unlimited range marker to be able to get the dashed line easily selectable, then switch back.
on....found that symbol that shows the limited vs. unlimited.
another question...how can I "select" the node which stretches them left or right?
it appears that some interior elevation markers can only be stretched up and down (meaning closer or farther to the tag) but I can't seem to stretch them left or right?
2016-09-13 11:25 PM
Richard wrote:I should probably clarify this. You CAN do this with multiple elevations tied to the same marker, but the nodes are like nodes on a polyline. Move it, and you may be moving the extents of multiple views at the same time.
There are a couple of issues. To get those nodes to display, you need:
1) A single elevation type marker. It won't work with multiple views in the same marker.
2016-09-13 11:29 PM
rob2218 wrote:or you could just use elevation markers
...seriously GS....you guys gotta reprogram these markers to be more like building elevation markers.
2016-09-13 11:32 PM
2016-09-13 11:39 PM
