2022-01-29 08:20 AM
Hello,
How do I import publishing set from existing to the new project?
The new project doesn't have the set…
Thanks
2022-01-29 03:04 PM - edited 2022-01-29 03:05 PM
Try the following:
2022-01-29 07:33 PM
thanks Eduardo….it doesn't work.
looking through past posts, look like there is no way to import publishing sets from an existing to the new project…I forgot to use the template I have set up and have already done so much work on it. I think I will open a template an copy and paste. thanks anyways!
2022-01-30 09:47 AM
Publisher Set items are based either on Views, or Layouts (which have Drawings based on Views). Views can not be exported-imported between Projects, I suppose because of the complexity associated with the process (you would have to export-import all settings that Views reference). I think this is the reason why Publisher Sets can not be exported-imported between Projects either.
2022-01-30 04:14 PM
Uff, misread the question to mean Layouts, sorry.
