Indicating both "FEET" and "METERS" in dimensions?
rob2218
How do I show both "FEET and INCHES" and "METERS" in my dimension strings?
there has to be a way to do this....thank.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
9 REPLIES 9
Aaron Bourgoin
Document Options - Secondary Dimensions
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.25 Mac
MacOS Tahoe 26.2
rob2218
ok....i'm a bit slow.
Where do you find "Document Options"?
Where do you find "Secondary Dimensions"?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok...I found it at the pulldown of:
Document>Annotations>Secondary Dimensions>Convert Dimensions....
but...as I stretch my object which stretches my "dimensions"...that secondary dimension does not revise itself automatically?
how can I get the secondary meter dimension to auto update?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Aaron Bourgoin
Go to Document Menu
Down to Document Extras
Across and Down to Secondary Dimensions
alternatively, you can type Secondary Dimensions into the Search Bar of the Help Menu and it will light up the tool you need.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.2
rob2218
I don't have a "Document Extras" in AC20?
is there an add-on?
I'm missing something.
Also..seems the dimensions don't "auto update" when I stretch my object the dimension is associate with?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Aaron Bourgoin
to update, highlight the dimension string(s) in question, go back to the same menu item and select "Refresh Converted Dimensions". just below
It's not automatic.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.2
rob2218
YES....I saw that "refresh" option but holy moly!.....really...it's a NON-ASSOCIATED text that resides under the actual dimension NOT automatic?.....Really GS? really.....out of all the things you didn't automate....this is NOT one that should have been left out.
Well, at least it's there. thanks for pointing that out.
I suppose I'll simply have to freeze all other layers, select all dims then do that process every time a new dimension is added....what a P.I.T.N.S.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Aaron Bourgoin
in 20
Document Menu
Annotation
etc.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.2
Marky
Another great feature I wasn't aware of and pretty easy to find.
I would be also interested in both square meters and feet in area as I need that once in a while.
AC 6.5, 13 - 19 Pl, OctaneRender for ArchiCAD, MoI 3D, Blender; W7 Pro 64;
i7-4790K/32 GB; GTX 980/4 GB
