‎2012-05-01
05:05 PM
‎2023-05-23
03:11 AM
Gordana Radonic
‎2012-05-02 04:30 PM
‎2012-05-02 10:50 PM
rob2218 wrote:Not sure you are listening properly. If your 2D toilet object has a white background fill and is brought forward of the linework it will cover it up. The line could be continuous but the part of the line behind the 2D object is not seen. Also beneficial if your toilet moves, you don't have to trim / extend the line again.Why are you trying to snap the linework to the 2d WC object?......well because as you can see...when a "base board" 2d linework is shown graphically "behind" the toilet...I'd like to make sure the line is trimmed/snapped/ended properly at the toilet elevation edge...you know..precision drafting....that's why I'm trying to trim/snap to the edge graphic linework of the toilet 2D object.....it's done all the time when you trim a line to an object....at least that's how I draw accurately.
