ā2009-01-13
02:31 AM
ā2023-05-23
03:13 AM
Gordana Radonic
ā2009-01-13 03:08 AM
ā2009-01-13 03:33 AM
ā2009-01-13 03:51 AM
ā2009-01-13 10:17 PM
fuzzymike2002 wrote:You can change the layer using Edit > Element Settings > Edit Selection Set... (or the hammer-in-a-square button within the Info Box). This was a bug in AC11 -- is it still a problem in AC12?
True, but you need to select the marker at the right point, ie selecting the marker head will not allow you to change the layer. You need to select the IE at the end of the elevation line, not the marker line.
I found this to be a little strange.
mike
ā2009-01-14 12:03 AM
ā2009-01-14 06:59 PM
fuzzymike2002 wrote:Because the IE tool is a mess. Most twisted is the fact that group IEs
So anybody have any ideas why it is not possible to change the layer if you select the IE by the marker head line in the Selection Settings or Info Box?
ā2009-01-15 05:46 AM
James wrote:Thank you, James, for this excellent site. I appreciate your articles!
To be fair, there are also shared quirks. More here, if you can stand it.
