‎2011-07-20
04:13 AM
‎2023-05-23
03:12 AM
Gordana Radonic
‎2011-07-20 04:16 AM
‎2011-07-20 07:47 AM
NickMcLeod wrote:Just click on the extent of the elevation you want to hide and use the "Delete segment" option on the pet palette.
Still, any chance of turning off individual elevations?? That would still be super useful.
‎2011-07-20 08:11 AM
‎2011-07-20 01:40 PM
NickMcLeod wrote:Look at Project Preferences > Dimensions > Level Dimensions (4th from left). Once the settings are correct, give the Standard a name, and assign this to the View in the View Settings.
I am noticing the story levels produced in the elevations do not correspond to the actual story lines, even though they sit where they should in relation to the floor.
Sorry, unclear description.. My floor level is AHD 99.510m, the story lines sit right on this level as my storey's are set correctly.. The RL on the story line however, reads +100m, so it looks like it has rounded up to the nearest meter..
I have been through all the project preferences and elevation settings and so on.. I cannot find anything to make these levels read accurately...
‎2011-07-21 04:37 AM
‎2011-07-21 02:49 PM
NickMcLeod wrote:Works here. If you post an image of your Dimensions Settings and your View Settings maybe someone will see the problem. I don't know where you can set anything in ArchiCAD to 10,000 decimal places, in the Dimensions Settings, using meters, the maximum decimals is 4.
Sigh.. No good..
This was the first thing I did. I can give it 10,000 decimal places, yet it still sits on one..
Attached is a picture. This shows the main problems I am having.. Firstly, the levels should be 99,510 and 102,510, rather than +100 and +103. This is unchangable through any of the settings..
