alessiofazzi
Is it possible to duplicate a Layout with duplicated view?
Hello Everyone,
I would like to duplicate a layout with all the view already set in. I can do easily, but when I change settings in the view of the copied Layot I also change the settings in the views of the original layout. Is it possible to "unlink" the duplicated view in the copy.
Thank you
Alessio
1 Solution
Ernest Atanasiu
make a duplicate of the views that are linked in the first layout and re-link these in the second layout.
this might help, too:
https://help.Graphisoft.com/AC/25/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC25_Help%2F030_Interaction%2F...
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
Go to post
3 Replies 3
Ernest Atanasiu
Turit
Press the ctrl and drag the layout below.
alessiofazzi
Thank you, it helped to solve my problem. Even if I hoped in a more straightforward solution in case of big layout with many views inside.
