ā2022-11-25
11:51 AM
ā2023-05-09
05:56 PM
Gordana Radonic
Hello Everyone,
I would like to duplicate a layout with all the view already set in. I can do easily, but when I change settings in the view of the copied Layot I also change the settings in the views of the original layout. Is it possible to "unlink" the duplicated view in the copy.
Thank you
Alessio
Solved! Go to Solution.
ā2022-11-25 01:27 PM
make a duplicate of the views that are linked in the first layout and re-link these in the second layout.
this might help, too:
ā2022-11-25 02:03 PM
Press the ctrl and drag the layout below.
ā2022-11-25 02:52 PM
Thank you, it helped to solve my problem. Even if I hoped in a more straightforward solution in case of big layout with many views inside.
