Is the second ADD possible in Expression of Property Manager?
LeeJaeYoung
IF ( COMPARE ( {Property:PRODUCT INFO/U_DoorType}, "PD" ) = 0, "ķ”Œė¼ģŠ¤ķ‹±", "" )
IF ( COMPARE ( {Property:PRODUCT INFO/U_DoorType}, "WD" ) = 0, "ėŖ©ģž¬ė¬øķ‹€", "" )
this is wrong
2. What I want to add is to be able to select if not in the if statement. ^^
AC27 on window 11
poco2013
Mentor
I assume your intent is that : If the door type is neither "PD" or "WD" then fall through to another message --- Otherwise I don't know. In any event you can use only one statement.
IFS ( {Property:Calculation data/Door Type} = "PD", "Is PD", {Property:Calculation data/Door Type} = "WD", "Is WD", TRUE, "Not Either" )
Gerry
4 REPLIES 4
poco2013
Mentor
The short answer is NO. Multiple statements can not be used in expressions unless they are used within the sequence block. Your intent is not clear but i believe you might want to use a IFS statement instead.
Gerry
Thank you for answer.
I'm always curious about your long answers. ^^
Should I use only one method of ADD?
(If it is possible to use it multiple times, I would appreciate it if you could show me the form.)
But why
I used it once, is it alive as I can add add?
AC27 on window 11
poco2013
Mentor
Gerry
thank you so much. ^^
With your help, I converted the if statements into ifs.
AC27 on window 11
