‎2022-05-20 09:10 PM
Hi is there a way to isolate a layer like in AutoCad? I particularly want to isolate all objects on the lighting layer but can't seem to find where to do it. Thanks !
Solved! Go to Solution.
‎2022-05-20 09:22 PM
Turn on the Quick Layers Palette
It should be in the Window Menu, near the end of sub-menu, Palettes.
Select something on a layer you want to "isolate" and click "Hide Others' Layer"
This Palette also has its own Undo Que.
‎2022-05-26 08:33 PM
Got it, thank you!
