‎2014-07-17
03:12 PM
‎2023-05-26
02:27 AM
Gordana Radonic
‎2014-08-22 01:32 AM
laszlonagy wrote:This is a major issue I am having at the moment Laszlo: I need to be able to format the
Also, I could not find a place where I could determine the default formatting for Revision IDs. They are always "01". I cannot set it to "001" or "1" or other formatting, or at least I couldn't find the place where I could.
‎2014-08-22 10:11 AM
‎2014-08-22 11:28 PM
laszlonagy wrote:
Maybe it is time for you guys to create a few Revision Management-related Wishes.
‎2014-08-25 11:39 AM
‎2014-08-25 02:15 PM
‎2014-08-25 11:39 PM
Gergely wrote:thanks greg - that is well worth knowing. the confusion lies with understanding that the issue ID and the revision ID are two separate things but that to change the
So Ben in your example, you only have to manually set the A revision, after that the IDs progress alphabetically, and with the first CD Issue, you should override all with 01, after that they'll progress numerically.
‎2014-08-26 12:32 AM
~/archiben wrote:so i managed to achieve the result i needed using the sheet index to manually play around with the #RevID: not pretty, not intuitive and whether i'll remember it the next time is to be determined....
so: the first issue from my project is "01" and this issue is most likely to contain a series of documents at revision "A" (i'll let go of the "-" revision to make things easier). how do i achieve that? and more importantly, how do i modify our template file to make that outcomeidiot-prooffor the rest of the people in the office who want to be architects not archicadicts? ![]()
‎2014-08-26 11:21 AM
Gergely wrote:Having got my head around the way the AC18 revision system works it looks like another big step forward for Archicad.
Your workflow should go like this:
1) Create First Issue, Issue ID: "-" (dash), check the "override Revision ID", close First Issue (All Layouts start with dash)
2) with every consecutive Issue, you'll have to check for RevIDs that are "-1", and replace them with "A", all the others will advance automatically. The best place to do this is the Sheet Index, where you can see and edit the current Revision ID of all Layouts - if you include the appropriate field. Practically, you only have to modify those Layouts, which are at their second version / first Revision.
‎2018-12-04 02:08 PM
‎2018-12-07 11:40 AM
