Achille Pavlidis
Issue ID/Revision ID discrepancy
When creating a new Issue, no matter what value I choose as the Issue ID, this is never reflected in Revision ID, but instead the default 01 value is assigned.
I then have to manually change the the Revision ID manually for each and every single Layout, one-by-one!
Could this be fixed please?
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
19 Replies 19
__archiben
laszlonagy wrote:
Also, I could not find a place where I could determine the default formatting for Revision IDs. They are always "01". I cannot set it to "001" or "1" or other formatting, or at least I couldn't find the place where I could.
This is a major issue I am having at the moment Laszlo: I need to be able to format the 'Revision ID': I can see how to over-ride/format the 'Change Numbering ID' and the 'Issue ID' seems to be automatically recognised based on the last Issue ID you typed in to the "ID" field (i.e. you can start with an issue "01" and the next one will be "02", but if in the next you over-write the "03" with an "A" the subsequent revision again will automatically be "B"....
Is it even possible? Massive oversight if not....
b e n _ f r o s t
I don't think there is an option to define this to be assigned automatically, it can only be done manually.
Maybe it is time for you guys to create a few Revision Management-related Wishes.
__archiben
Seriously? Something so basic makes the wishlist and the feature has only just been released....?!
I just googled architectural document revision examples and there is a fair mix of numbers and letters as standard conventions, (a couple of combinations too) and that was with 30 seconds of research. It's just so disappointing that we can't recreate what is a long-established standard here because something that basic and easily resolved (most other archicad features making use of a alpha-numeric systems can be customised!) has been missed . . .
for what it's worth, we start with no revisions (a dash "-" for example), because nothing has been revised before moving on to A, B, C on a by-layout basis as revisions occur throughout the Sketch Design, Design Development and Construction Documentation phases. At the point the drawings are release for tender the entire set becomes revision "0". All going well, Construction Issue should be revision "1" and they clock up 2, 3, etc... from there. Too difficult? I'd happily miss the dash at the beginning if that proved too hard, but surely the rest is basic enough?
B
b e n _ f r o s t
Gergely Hari
To clear things up a little ID-wise:
Revision ID always gets assigned based on the previous Revision ID, on a Layout-by-Layout basis.
So if one Layout's latest was 03, the next will be 04, while the other Layout, which is at Revision C, will continue with D.
So you only have to modify them manually when there's a change in the numbering logic, otherwise it will progress based on the previous ID.
Issue ID follows the same principle, the new Issue ID is generated based on the previous one. Issue ID is a completely separate identifier, which - as the name suggests - only identifies the Issue itself. For certain cases, where the entire documentation restarts its Revision numbering (ie. D&D -> CD transition, where lettering switches to numbering or vice versa), it can be used to override all the Revision IDs in it - after that, RevIDs will follow from that ID - same as if you manually modified the RevIDs of those Layouts.
But essentially, they are separate from RevIDs, and you should only use / display RevIDs on the Layouts, because that's what progresses on a by-Layout basis.
So Ben in your example, you only have to manually set the A revision, after that the IDs progress alphabetically, and with the first CD Issue, you should override all with 01, after that they'll progress numerically.
The problem with the "dash, A, B, C" numbering logic is known. As far as Layout revisioning goes, there are different numberings around the world, starting from one (version-numbering) like 1,2,3,...; A,B,C,...; or starting from zero (revision-numbering), 0,1,2,3...; nothing,1,2,3,...; and your case, nothing,A,B,C,... All the others are pretty straightforward, but since there are two schemes that start with nothing, and follow with different values, you'll always have to determine which one you want with the SECOND version (first Revision) of the Layout. (technically it would be possible to use special characters instead of the dash, that determine whether to follow up with numbers / letters, but that's overcomplicating things compared to manually setting A when it is necessary). Not straightforward to solve without screwing up the numbering system for others using different methods, still we're investigating.
And since there could be different Layouts in different phases (with different numbering), this cannot be a project level setting either, you'll have to do this on a Layout-basis.
Your workflow should go like this:
1) Create First Issue, Issue ID: "-" (dash), check the "override Revision ID", close First Issue (All Layouts start with dash)
2) with every consecutive Issue, you'll have to check for RevIDs that are "-1", and replace them with "A", all the others will advance automatically. The best place to do this is the Sheet Index, where you can see and edit the current Revision ID of all Layouts - if you include the appropriate field. Practically, you only have to modify those Layouts, which are at their second version / first Revision.
(After the first regular update, you'll be able to set Revision IDs for multiple selected Layouts in the Navigator / Layout Settings as well, but still, the Sheet Index should be the most convenient place to do this.)
best regards,
Greg
Gergely Hári
Principal Product Designer
Thanks Greg for this info. Honestly, I did not know about this feature that you can rename a Revision ID of a Layout, for example, from "02" to "A" and then the next Revisions will automatically become "B", "C" etc.
So the reason there is no separate place or Dialog for defining the automatic formatting of Revision IDs on Layouts is because whenever you change the format of a Revision ID to your liking, ArchiCAD will just follow that from there on. And that format can vary from Layout to Layout.
By the way, just so you guys know, Greg is the Product Designer at Graphisoft HQ who has been working on the Revision Management feature, so this info is "straight from the horse's mouth".
__archiben
thanks greg - that is well worth knowing. the confusion lies with understanding that the issue ID and the revision ID are two separate things but that to change the revision ID manually we have to use the issue ID...
when i approach new features i am always thinking, 'what is the least complicated workflow that will achieve my goal' because that's what most users need in order to adopt and embrace something. whilst this is plainly obvious now that you've explained it it's not suggested by the interface when you create that first issue. it even caught laci out by the looks of it! something to work on..?
and finally a question to screw things up further:
issues are releases of information. there is the first issue all the way through to the last issue. being the first issue it's generally called '1' (or '01'): i.e. it's a numercial thing. revisions can be alphabetical or numeric (in our case we're alphabetical up to the end of construction documentation and than numerical with the first tender/construction issue).
so: the first issue from my project is "01" and this issue is most likely to contain a series of documents at revision "A" (i'll let go of the "-" revision to make things easier). how do i achieve that? and more importantly, how do i modify our template file to make that outcome idiot-proof for the rest of the people in the office who want to be architects not archicadicts?
i'm sure this is not an uncommon occurrence - 4 of the last 6 companies i've worked for in UK (1) and NZ (3) worked like this, (the others didn't have any kind of system in place anyway!).
~/b
b e n _ f r o s t
__archiben
so i managed to achieve the result i needed using the sheet index to manually play around with the #RevID: not pretty, not intuitive and whether i'll remember it the next time is to be determined....
- start with issue 01 and ensure that the issueID is set to not overwrite the revisionID
- change all (default value) "01" revisions to "A" in the Sheet Index
- issue #1: if the sheet index is filtered in such a way that it doesn't show all layouts in the current issue you may miss some;
- issue #2: if new layouts are created subsequently they still become "01" and have to be chased down and changed...
none of which helps with helps with my second question: how to make it idiot proof. surely just creating a place where we the user can set a default value would be more appropriate? there is already a dialogue where this would be right at home already: "ID of Items in this Book/Subset/Layout" in any one of the Book/Subset/Layout Settings would be the place to find it....
b e n _ f r o s t
DGSketcher
Legend
Having got my head around the way the AC18 revision system works it looks like another big step forward for Archicad.
By way of feedback the above workflow aligns with my local standards but it does feel awkward as there appears to be a need for constantly checking the revision numbers of new layouts and second issues with changes. I have no problem with the issue numbering but the revision ID needs to be more reliable and automated. I have never seen a drawing issued with a revision ID associated with no changes; it makes more sense to me that the layout revision counter only starts when a change is noted within the layout.
Clearly the system needs to work globally but it would be a lot more user friendly if the Revision Manager allowed for pre-setting the projects revision style e.g. alpha or numeric together with an option to include or ignore the revision counter with the first issue.
I have spotted that the GDL revision object allows for hiding the first entry but as was pointed out previously there is that awkward transposition from the first issue to second revised issue marked as "A" where the process is frustrated.
Has anyone knows if this issue has been solved for Archicad 21 , seems still in the same situation than 2014.
I am not aware of any new developments since the original introduction of Revision Management features in ARCHICAD 18.
