Issuing a set of drawings without having to revise all included layouts
This might come down to my level of understanding of issuing drawings.
We issue several sets of drawings and indicate through the Issue Name what that issue is for.
For example "Construction Issue", or "Pricing Issue". This is displayed on the titleblock of each layout.
The problem I am experiencing is, often particular layouts have not changed since the last issue, therefore no revision (change) required. This in turn causes the issue name to remain the same as last time it was issued.
At the moment we are having to add a change to each layout, to cause that layout to revise, with a change note something to the effect of "this layout has been issued for pricing", which shows in the revision table.
Contractors are contacting us saying we have a layout which is at Revision F, what's changed sinced Revision A?
The answer is simply, nothing, we have just sent that layout out several times for tender etc.
Thanks in advance to anyone that can guide me in the right direction.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
2 Replies 2
Lingwisyer
Guru
Just clarifying, you want it to go something like:
Rev A - Issue for Coordination
Rev B - Issue for DA
Rev B - Issue for Tender
Where you have included the drawing in a new issue without any changes.
Ling.
Hi Ling
Yeah, that's exactly what we are after.
