Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Item's separated all over!
I am using Archicad for 2 month now. Student Template of uni.
suddenly my items kind of exploded to many pieces. For instance, Tree, changed to 100 parts and everywhere I see cross. Guess something to do with views. They look fine on Layout block. All messy in View Map though Any way I can fix it?
Thanks
6 REPLIES 6
Erwin Edel
You either copy pasted some things (objects) or exploded them.
The 'crosses' are just hotspots, they don't show up in PDF or print.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks. Whole things being copy and pasted many times as per what teachers asking, but never appears this way! Can be fixed though?
If you have exploded and object, there is unfortunately no way to un-explode it (unless it was the last thing you did - then 'undo').
You would have to delete and put back the origin object.
If you want to get rid of the hotspots, then select the hotspot tool in the tool bar and then press CTRL+A.
This will select all of the hotspots in that elevation.
If you are happy with that selection you can just delete them.
If there are other hotspots that you would like to keep, then you will have to de-select those before deleting.
Thank you. I didn't explode any item. Just checked the shortcut, its CTL=+ and no way I've accidentally hit it
Copying & pasting in elevation will automatically explode what you copy as it doesn't actually copy the 3D element (if it was a 3D element).
Thank you Barry
