JPG files in Plot Maker
we have just moved to AC 10 & are have a problem with plot maker
i have rescripted out title block to import our company logo as a JPG thru the picture2 command into our title block as well as a number of other symbols.
the gdl part is working successfully, however, when dropping the object into our master drawing the JPG files are disappearing when we return to out plotmaker layouts.
if i place the JPG files into the master sheet independently of the title block they seem to appear ok.
i'm not sure if i am scripting the GDL part incorrectly or i have a problem with plot maker
1 Reply 1
Djordje
No PlotMaker any more ...
Check your layers, and display options.
Do you see the JPG when defining the Master? If you do, it is there, so you should check the visibility of the Master elements in the layout.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
