2004-10-14
10:54 PM
2023-05-19
04:06 PM
Gordana Radonic
2004-10-18 06:46 AM
2004-10-18 02:08 PM
Matthew wrote:Matthew... don't understand this ref... publish modules?
and now we can Publish the modules. Much easier than the old process of: open view, copy to clipboard, save as module, repeat, repeat, repeat...
2004-10-18 04:44 PM
2004-10-18 08:15 PM
2004-10-20 09:51 PM
I've included all of the office standard details in the template file. Modules are each placed into their own detail window, and named accordingly. The detail window is numbered with a letter to denote the type of detail (M=millwork, P=partition, D=door) followed by a number (01, 02, etc), and named with the file name of the module as located on the main server. I spent time to create properly named views for each detail in the View Sets window, but now they won't need to be changed. The autotext reference saved in the detail title works well in this case.Wes,
2004-10-21 07:40 AM
Does this mean that your template file has all your typical details in Detail windows, Just sitting on a floor plan, in a random location? Doesn't this make your file large?It seems that Wes places each detail into a(n unlinked) detail window of it's own, as opposed to placing them in a floor plan window. With a subtractive methodology, as Wes is using (deleting an used/unnecessary detail is easier than adding it), this is a method that I agree strongly with. Yes it will add to your initial template file, but IMHO speed should be a higher priority than space, in this day and age. Besides, a detail shouldn't be too big - I'd guess around 50Kb - even 100 of these would only be 5Mb.
2004-10-21 08:04 PM
Link wrote:That is correct. The detail markers can be added when there are actual drawing elements to be keyed (just select the option to link the tag to an existing detail window in the cmd-T window) As most of our details are sectional, or standard plan items that don't require a reference to model elements, there is no need for a link to the model, or even updating the detail window - ever.
Link wrote:Not in the templates. Much of our standardized work and details are interior - like millwork details, and there are probably 6 or 8 options for a base cabinet, only 1 or 2 of which might get used on a particular job. It is far easier for us to simply assemble the sheets in Plotmaker while cartooning the set - using only the details you think you might use.
What I'd like to know Wes, is if you take this a step further and place views of these details onto sheets in PlotMaker?
2005-05-12 07:55 PM
2005-05-12 11:04 PM
2006-02-05 07:20 PM
