Bling Keeta
LEVEL DIMENSION QUESTION
Set site mesh Home Story at 690 from Sea Level
(Sloping site from 690' to about 737')
Set Project location at 704' altitude.
Site home story set at 0'
Select gravitate to mesh.
Select level dimension and click on mesh.
It shows elevation value from 0' to 47'.
But will correct itself to the Sea Level value if I go into Dimension Text Setting/Custom Text/Insert auto text/To Sea level.
What have I missed? Thanks in advance.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
3 Replies 3
Bling wrote:
What have I missed?
Not much.
http://archicad-talk.graphisoft.com/viewtopic.php?t=27676
Bling Keeta
I can't believe it Graphisoft still hasn't addressed this problem since 2009!
it's a real mystery why it is not perceived as important and a basic function.
Ben Ling
AC 20
Link
There is still a relatively easy workaround as mentioned here.
Basically just have one story at the bottom of the project and set the height of it to match your height above sea level (or any other level you need to reference from).
Link.
