yyeellddaa
Label Lenghts
Hello Graphisoft Community,
i just labelled all walls in a floor. and i want to have a shorten label. i guess there is a defaul setting for how long it will go then break and after how long the text will occur. i want this first two arm to be shorter automatically (not manually). can you help? thank you.
Setup info provided by author
1 Reply 1
CosminF
Unfortunately, as far as I know, there is no control over pointer length, just the angle.
You can at best change the scaling of the drawing or use the Geometry Method: Detailed to redo the position of each label.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
