DS6
Label does not pick up element information
Hi everyone!
I’m having an issue with the Label Tool. I use it as an annotation tool to display information such as wall or window IDs, or elements’ top elevation to sea level. It has worked fine so far, but it suddenly stopped picking up element information.
Has anyone else experienced this issue or knows how to fix it?
Thank you for your help!
1 Solution
kmitotk
Make sure the geometry method is set to Associative.
Kei Mito
MITO architecture + design
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
Go to post
2 Replies 2
kmitotk
Kei Mito
DS6
Thank you so much!
