2016-08-04
06:33 PM
- last edited
a month ago
Aruzhan Ilaikova
2016-08-09 09:37 PM
ESP182 wrote:Probably.
I'm guess that Graphisoft never designed a Rotated Square with a leader line and pointer?
2016-08-10 07:47 PM
2016-08-10 07:49 PM
2016-08-10 11:45 PM
ESP182 wrote:I don't think so. From what I see the pointer can only be connected on the left.
But is there a way to have a label with the leader, with a pointer, coming from either the top or bottom, not left or right sides?
2016-08-16 05:58 PM
2016-08-16 07:40 PM
ESP182 wrote:I looked into this from different angles, but this might be a bit more difficult than usual.
Looks like I'll have to make a wish list item for this? Until then, I'll continue using two different labels to make this happen. Works around ftw!
2016-08-16 07:43 PM
2016-08-17 03:53 PM
Anton wrote:It can be solved with custom scripting, but you'd have to script the whole thing, including the lines, pointer arrow and bypass the label position.
... We can't even solve this with custom programming, as ArchiCAD does not even have an option to attach pointer to the top or bottom of a label.
The only variable available to us (LABEL_ANCHOR_POS) is hardcoded into ArchiCAD to only allow attaching pointer on the side of the label and, then, has only three positions — bottom left corner, left middle and left top corner....
2016-08-17 10:26 PM
sinceV6 wrote:That won't be a label, though.
2016-08-17 11:32 PM
Anton wrote:Why not?
