mukster
Labels in Archicad 20
Just switched over to Archicad 20. I usually use the label Ident Device Indic_DCS 18 to label drawing objects, but it is apparently missing in Archicad 20. Any thoughts? It shows up on some older labels, but I can't find it on the new label selections.
Mac platform
1 Reply 1
You should consider that type of information you wish the Label to display (such as ID, Height, Dimensions, etc.) and then select the Label type that can display that type of info.
