2016-12-0105:47 PM - last edited on 2025-02-0711:36 AM by Aruzhan Ilaikova
2016-12-0105:47 PM
Just switched over to Archicad 20. I usually use the label Ident Device Indic_DCS 18 to label drawing objects, but it is apparently missing in Archicad 20. Any thoughts? It shows up on some older labels, but I can't find it on the new label selections. Mac platform
You should consider that type of information you wish the Label to display (such as ID, Height, Dimensions, etc.) and then select the Label type that can display that type of info.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
