Larger detail bubble
Many times, if I make a detail bubble I need to make it bigger (or smaller). How do I resize
the bubble?
Thanks!
4 Replies 4
Just select the bubble & stretch as you do with any polygonal shape or object.
I've tried that. It won't stretch.
Dontknow
Select it, then select it on the side where you want to stretch it and use 'Offset Edge' in your pet-palet and stretch it.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
David Maudlin
Jack:
It should stretch like any polygonal tool (the Pet Palette should appear with Offset Edge as an option). It may help to turn on the on-screen option Marker Range, as this will show the edges of the editable polygon.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
