SOLVED!
Layer Name Simplification
Zdenko
is there a way i can globally modify layer names? for example i find the A - Annotations..... layers way to long in characters and would like to shorten/abbreviate and would like to eliminate all of the "-" in between words.
Operating system used: Mac Intel-based Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
1 ACCEPTED SOLUTION
Solution
Xandros
You could try exporting it via the Attribute Manager by Index and do a search and replace in editor / notepad ++ for example and reimport it by Index again.
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
10 REPLIES 10
Globally edit a list of layers - no.
You have to amend each layer name individually.
Solution
Xandros
Good thinking Xandros, that does work.
You just have to be very careful with the find & replace that you are only editing the layer name in the XML file.
The '-' for example is also used in the GUID numbers.
But if you are searching for ' - ' (space -  space), then it should be easier to find just in the layer name.
I'd love to do so in Excel since it can handle xml-files and it would definitely be safer (not changing things that doesnt need to be changed) and there are more tools at hand to do systematic replace of text, but haven't figured out a way of saving it back to an xml that is still readable for ArchiCAD.
Archicad XML files use complex XML mapping tables, that can be read by excel , but it can't be exported back to XML
you need to use Notepad ++ or some advanced coding skills with python
Archicad 27
Windows 11 professional
thanks Xandros and Barry! I am very comfortable with Excel and XML, will give it a try here shortly on my TPL file.
Sequoia 15.1.1
bouhmidage - should have read your message before trying! does not work in XML which s..ks... will try Notepad
Sequoia 15.1.1
well i am SOL? Notepad++ is Windows based and requires too much brain damage to get it running on OS, if i come across anything will chime back in.
Sequoia 15.1.1
Ahmed_K
Mentor
Try this,
Easy XML Editor - XML Software (edit-xml.com)
Archicad 27
Setup info provided by author
