Layout book/view map
mukster
Ok, I have a weird problem. Archicad 23, MAC platform. I have a label showing up on a page in the layout book, but when I open the view map, it isn't there. Updated the layout book, showed all layers, just can't get the label to show up on the view map.
Hello mukster,
Is your label on the layout ?
Do you have few views into the same layout ? Do you select the right one ?
Do you have some white pen which make your label invisible ? (select label tool then cmd+A to select all labels)
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Stress Co_
Is it on the master layout?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Select the drawing on the layout.
Right mouse click and then 'Open Source View'.
If it is there you will see it.
If it is not in that view then it is separate on the layout or in the master layout as suggested.
