2003-11-29 01:01 AM - last edited on 2023-05-30 10:10 AM by Rubia Torres
2003-11-29 10:55 AM
BryanRichards wrote:you set the plot page size from the
-my plan appears on the layout but how do i know how big the layout paper is? if i goto page setup and select A1 no proportions of the layout change from if it was set to A4?????
BryanRichards wrote:i think maybe that you have moved the drawing out of frame somewhere. if you miss one of the corner/side nodes of the frame when you drag it, and instead click somewhere within the frame, you actually end up moving the drawing elements themselves
-Ive now selected the plan and moved it but the plan has vanished leaving me with a black square outline with the word 0.story @ the bottom?? is it supposed to do that?
BryanRichards wrote:depending on the settings i have just described, yes it will print OK -
will it print ok even though the actual graphics are not there just the outline of the window???
BryanRichards wrote:this is where i can't really help you. it sounds like it could be a memory issue. you really somebody with PC experience to decipher this one.
-i then import a section from the same .pln file using the same process onto the same layout to place next to the plan. The update proceeds to about 25% (two beeps)
-I then get an SISGL window saying "warning, cannot create a new surface, out of video memory. This program will exit" i click ok (the only thing to click)
-a window appears saying "Error while generating view in ArchiCAD."?
2003-11-29 04:24 PM
BryanRichards wrote:Quite normal snags ... and you still have not read the book, i see
Ok, i need to layout my sheets now ive completed my drawings. Im trying to set out an A1 sheet with plans + sections @ 1:100 and renders etc. But im hitting a few hopefully minor snags.
-I then get an SISGL window saying "warning, cannot create a new surface, out of video memory. This program will exit" i click ok (the only thing to click)Uh - oh ... Ben answered your PlotMaker related questions, this is the PC one ...
-my layout currently looks like the picture ive posted.
2003-11-30 02:26 AM
It seems that your video driver's OpenGL implementation has a lot to be desired for (with SiS not very unexpected ...) Try switching off the OpenGL everywhere in ArchiCAD, download the newest drivers. You should use a better video chipset with more memory with ArchiCAD 8.yikes, alarm bells ringing now, god help if this is a perminent problem. ok so this may seam tedious, but how do i turn off OpenGL in archicad 8?
- set the Master as needed (A1 or whatever)-ok got that except your last point there. (open the pln in archicad 8 first?) before importing?
- make it default
- whatever shows on all sheets, let it be in the Master
- Use Autotext for sheet names, project names, etc
- when ready to import, open the PLN, choose your viewset, and import each view onto a new layout (the new layouts will be automatically created)
HOWEVER - it sounds like you have a SERIOUS problem with the video subsystem of your computer, and of course it will show up ona deadline ...-dont say that!
2003-11-30 02:50 AM
2003-11-30 04:11 PM
2003-11-30 04:14 PM
BryanRichards wrote:Don' you have a radio/walkman/whatever? Music players:
-Ive just restarted my computer, closed all my apps (no music now ) maybe thats why the plan works, i always import that first
-To let you know my exact spec is http://www.uktsupport.co.uk/advent/faq/laptop/7013.htmHope it was a present ...
what do you make of this, its a laptop remember so upgrades can be a little tricky (i just got it, dont say its no good already lol )
yikes, alarm bells ringing now, god help if this is a perminent problem. ok so this may seam tedious, but how do i turn off OpenGL in archicad 8?In 2D it is off by default, in 3D also; but this is not the problem EXCEPT if you saved your 3D views with the OpenGL active in the 3D window, in which case you will get solid black rectangles in PlotMaker.
-How are my views defined. I cannot see anything here for defining views to give an answer but i can say my plan seams ok at the minute, lets wait till i import a sectionA view set is a set of views
-defining my viewsets. i searched through the help for defining viewsets, i found nothing. How do i define my view sets? im obviously not doing it becasue im not sure what it is
-am i importing one by one: Well for this excersize i am importing one by one on the "current layout". Only because i thought this would have gone easier on the system resources. I would however import the .pln and select everything i need. Is this the right way of doing it?When you open PlotMaker, set your Master (even better, create a template file and always start from it, saving it under a proper name for the project) and Import - find the PLN, find your view set, check all you want to import, and choose the option Append new layouts to layout book. Now you have a bunch of layouts, after the chugging is done, and you can arrange them as you like.
- You say i should be creating new layout options. this will plot each drawing to a separate page, am i right?. Will i then be able to have the plan and section in the same page? and rendered images?
-ok got that except your last point there. (open the pln in archicad 8 first?) before importing?No, you are not
Nononono, you are short on memory anyway. Keep ArchiCAD closed - one is being open when you import anyway.
lets just say if all fails, ill attempt the export as .dwg and layout in ADT2004 which is not what i want to do!!!! {/quote]
Do this and you are out of this list
YOUR ON YOUR OWN!! but not anymore.
2003-11-30 05:26 PM
2003-11-30 05:30 PM
BryanRichards wrote:That is another way to do it.
publishing to plotmaker!!!!!!!!!!!!!!!!!
now there is the answer. It seams to import that as if it was a 12kb jpeg. Its done instantly with no SISGL memory errors.
2003-11-30 05:56 PM
