Level Dimension with Gravity
My question is, How to delete the Level Dimension which linked to a Slab?
I found on my case, it may not be deleted independently.
I should delete the slab as well.
When I pick the label, the Edit > Delete button turns to gray.
What should I do then? Thanks in advance.
3 Replies 3
David Maudlin
Riva:
Two possibilities:
1. The Dimension is on a locked Layer
2. The Dimension is Locked
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David thanks for your reply.
I guess I'm just having too much coffee and lack of good sleep.
Here is my problem came from:
I used the level dimension without the symbol, just a clean text with frame.
Then, after I put them on the slab, I moved them around to have a better layout. Without any suspicions, I just dragged and dropped them by holding on the beginning of the text node. I thought that was the hotspot of the symbol.
And that was how I used the node to select it and tried to delete them.
Nothing is happened, because it is not the correct node.
The solution is to revert the position of the symbol, by selecting the text, and go to the info box, look for the revert position button. Then select the correct node which lies, hidden in the centre of the dimension text. YES.
David Maudlin
Riva:
Thanks for posting the solution, one that would not have occurred to me. Someone searching the forum later may find this valuable.
