SOLVED!
Library pieces not loading.
JessicaBoll08
I recently had to reinstall Archicad 26 and now one of my drawings will not show the window or doors.  I have reload the libraries, migrated the libraries.  It looks like there are objects that are missing have a (1) after them, and I have no idea how to fix it.  I cannot even open the missing object to change them to something else.
11 REPLIES 11
@JessicaBoll08 Actually, use this link to download build 4022 directly:
https://graphisoft.com/resources-and-support/downloads?localization=USA&type=FULL&version=26
The link that Lee gave should give the same file... but for whatever reason, that link gives build 3001 which you would then immediately have to update to 4022.
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
JessicaBoll08
Okay, so I have the USA version of the software installed.  I have the one drawing open, that I was having trouble with, but now I am getting this error message whenever I try to open another drawing.
