2021-06-2809:33 PM - last edited on 2023-06-0711:23 AM by Gordana Radonic
2021-06-2809:33 PM
Is there a way to set the sensitivity of line angles? For example, When I draw a line in Archicad, it will read as 90 degrees. When I export to DWG and send to a coworker, the line will read as 89.781572 degrees in PowerCADD, and is not straight. We have measured and measured, and it has to be a sensitivity issue. I can't however, seem to find anywhere to fix it. Any thoughts?!
Very possible that line WAS drawn in ArchiCAD on the able, mentioned in another CAD. Just because it's 89.7... and angle dimensions are set to show only numbers before point - ArchiCAD is rounding it to 90 degrees.
Try to draw your lines holding Shift key - you will get strict 90, 180 and 270 degrees. Also switch on two decimals in angle dimensions and working units - then you will get better picture on the angle.
