Brockway
Lines and text not appearing on master layout
I am not able to place text or other 2-D elements on the master layout. The text block will show up, but way off the page. I can not get it to be on the page. The same happens when I try to draw lines. I also tried creating a new master layout and the same problem persists.
I am using Archicad 23 on a Mac
1 Solution
I'm guessing that you have Grid Snap turned on.  Go to the View menu and uncheck Grid Snap and see if that helps?
Go to post
Brockway
How did I miss that?! Did the trick. Thank you!
