2021-02-23
01:20 AM
2023-05-19
11:10 PM
Gordana Radonic
2021-02-23 01:56 AM
2021-02-23 02:23 AM
LaszloNagy wrote:
Can you post which Archicad version this is happening in (e.g. AC24 INT Update 5000)?
What kind of Markers are these? Detail Markers? Worksheet Markers?
Do I see it correctly that you have an Elevation Viewpoint, and there you placed these Markers (in the other project file)?
The Linked Marker, what type of Marker is it, and what type of Viewpoint it is linked to? The Viewpoint it is linked to: is it set to Auto-rebuild, Manual rebuild, or Drawing type?
2021-02-23 02:39 AM
Narska wrote:
AC24 USA 4018 running on Mac.
This is happening to all my linked markers in every type of viewpoint. It does not matter whether they are on a floor plan, worksheet, or elevation. It does not matter if they ArchiCAD markers or costume-built ones and it does not matter what they link to. Source markers display the correct link.
Same behavior whether they are linked to drawings or live views.
The drawings are always manual update. I will see if that could be a problem.
I have a teamwork file that is my main model file and then I have a teamwork file that I created layout sheets in. The same thing is happening when I import views from a teamwork file into a newly created solo file. Linked markers lose their link.
Is this behavior a normal limitation, some kind of bug, or some kind of specific issue to my situation?
2021-02-23 01:26 PM
2021-05-03 09:24 PM
