krab-El
Linked drawing
For some reasons, I have duplicated a drawing in the same layout. The idea is to show different details on them using separated layer combinations but each time I change the setting of one drawing, it automatically affects the other. It is possible to unlink both drawings or make them independent?
Thanks
1 Solution
krab-El
Thanks for your help.
Go to post
4 Replies 4
scottjm
Mentor
Do you have each drawing on the layout sheet linked to a separate saved view?  Or are they linked to the same saved view?
krab-El
The drawings are linked to the same saved view.
There is your problem.
You need to save separate views and each can have different settings (i.e. different layer combination).
Then place each view on the layout.
krab-El
